KillerAngel
Relevant system specs are below if you're wondering. Basically, I want to OC my A64 a bit because I think it's preventing my new 7800GT's performance a bit from reaching its potential. However, I'm really only willing to run the processor out of specs (it's a year old, and easy to replace if something goes wrong). I'd like to keep everything else within spec: RAM, PCI Bus, etc.
So I did a little calculation, and I think I'll start with 240 HTT, which would give me 2160MHz, 960 HTT, 200MHz RAM, etc. It looks like everything will be running within specs with that, right? My big question is: will I have to increase my CPU or RAM voltage to compensate? It seems to me I tried this configuration a while back without increasing voltages and the system didn't post, but it was a while back and I could be wrong about the settings I used.
So, if a voltage increase is warranted, how high should I increase it for this settings? Also, if I wanted to take it all the way to 2400MHz, I would need to increase HTT to 300 to keep everything else in spec. I've read some mobos have a problem with this. Does anyone know if 300 HTT is possible with my mobo? Thanks a million, guys.
System specs:
A64 3000+ Winchester
1GB Mushkin Green RAM
XFX 7800GT PCI-E
MSI K8N Platinum mobo
Antec 480w NeoPower PSU
Update: OK, I finally got around to messing with it a little last night. I've had good results thus far: completely stable at 2160MHz (240 FSB, 166 RAM, 4x HTT) with no voltage modification and the temps don't exceed 38C on full load. However, I seem to hit some kind of invisible wall. If I try to take it above 240 to 245 or 250, it won't POST. I've tried lowering the CPU ratio, memory down to 133, HTT down to 3, nothing. I even tried upping the NF4 voltage to 1.55 and it still won't post.
Am I overlooking something? The only thing I can think of would be the CPU's voltage, but I don't see why that would need modifying as the actual speed is actually less than the stock value and it shows total stability at just a couple MHz lower FSB. Thanks in advance for your advice.
System specs:
XFX 7800GT PCI-E
