Ok guys, I'm posting this for a friend. Just to add to what he wrote me via email, I believe he's using the 300W PS that came with his Enlight case...like the 7237 or whatever it is called. Let me know if you have any ideas or need more information... I have no idea after talking to him.
Thanks in advance,
-Beej
--------------------------------------------------------- Message from friend -------------------------------------------------------------------
Beej, how are you doing. Dammit kid, i buy all these brand new parts and my processor has to go and be stupid and not work...or it could be my motherboard. Here is a description of what happens and what ive done about it.
I started out with EVERYTHING put together in my computer--hard drive, cd drives, processor, memory, video card, etc. When i first turned it on, it stayed on for 5-10 seconds, then powered down for no apparent reason. After playing with the power switch a whole bunch, i was able to cause the processor to make a "popping" noise, and then after that the computer would stay on, though without any POST or input to the monitor. Now my motherboard has a feature where it talks to you and tells you what is missing in it. It said nothing until the POP--then it said it couldn't detect the processor, meaning it was probably broken, so i sent it in for a new one. When the new one came in, i had already spoken to ASUS tech support and they told me to put my motherboard on a piece of wood, to eliminate any grounding problems, and then just put my processor apparatus on (heat sink, fan, processor). When i did this, it did the same thing. Stayed on for 5-10 seconds, then powered down. Again i played with the power switch, and i got it to POP and broke it again. I sent in for another new one, but i also sent in for a new motherboard--a RETAIL version this time, to eliminate any possibility for defects.
Unfortunately, nothing was defective and the problem still remains. The possibility stands that my processor isnt getting cool enough, because my motherboard would power down in that situation, but AMD tells me there's no way a processor can get THAT hot THAT fast. We've also played around with jumpers, etc. Now, the processors i've been using have always been OEM, so i got a refund on it and am now ordering a RETAIL processor, to eliminate any cooling problems. If this doesn't work, i think im just going to flash the bios (Thats what ASUS suggested). or eat my processor. depends on how hungry i am. Here are the parts im using:
ASUS A7V333 motherboard
Socket-A AMD XP 1900 processor
Thermalright SK-6 heat sink (with thermal pad)
Sunon 60x60x25mm fan
300 watt power supply
Thanks in advance,
-Beej
