Either the solenoid is not functioning, or it is not getting the voltage from the ignition switch (telling it to relay the two posts.) If you have a voltmeter, see if the smaller wire is getting a signal when the switch is turned to start.
If it is getting a signal, it is a bad solenoid. If it is not getting a signal, it is the switch or wiring in the switch circuit.
