Going wireless
casper114
814
Well first of all if he is going to be using this stuff for financial reasons I would suggest hard wired. Though if you must for the convinience of wireless I love my linksys g router and it's 128 bit encryption, i havn't found any software that can crack it. I usually have no trouble with connection problems either, but i set it up on a different channel then default too.
Valkerie
Banned
May 28, 2005
1,148
-get the best hardware-encryption devices
-wireless G, not B
-if connected to the 'net, double check which hubs and routers you're getting (it matters)
