going to stop climate prediction
ElFenix
102,393
8,552
the fact that it crashes and starts over just about every time i restart windows is annoying. i haven't done a backup in a while so i lost a ton of work when the power went out over the weekend. i'll finish this work that is projected to take a week and a half but then i'm done.
what should i switch to?
Philippart
1,290
I recommend rosetta, it's stable, has great goals, good deadlines, you can set the duration of the WUs and it's extremely rare that it runs out of work.
Worldcommunitygrid would also be a good choice. Join our new team, they support a number of projects that benefit humanity, the apps are stable and they hold the record of being pretty much never down.
Assimilator1
24,152
517
Or you could go with DPAD ,stable client ,easy to run ,produces its own WUs so never runs out of work ;)
TA DPAD is a small team (active users) but we're heading for the top!:Q ,still ,any addition makes a difference:)
Whether it's your sorta thing though is another matter ;)
ElFenix
102,393
8,552
Originally posted by: Assimilator1
Originally posted by: ElFenix
i'd like boinc projects if possible
Not even if it looks like the old SETI classic CLI window?;)
that thing was awesome.
line after line of FFTs.
but i like my integrated stats.
