Originally posted by: fyleow
My dad does about 100 miles a day with his car and I was wondering, does sticking to 65 actually save gas? I understand that it keeps the engine revs down but will it make much of a difference? He says that past 3000 RPM the engine starts to burn a lot more gas.
But IMO the only gas burning part about driving fast is in the city where you need to burn a lot getting up to speed during starts and stops. If it's the freeway and you're just slowly accelerating up it shouldn't matter as much right?
Originally posted by: fivespeed5
if he drives slow tell him the stay the hell out of the fast lane. I hate people who go 65 in the fast lane.
Originally posted by: BigSmooth
http://www.fueleconomy.gov/feg/driveHabits.shtml
Smaller, more aerodynamic cars will see less of a decrease in fuel economy at higher speeds.
Originally posted by: bolsen
Going slow does not always mean better fuel consumption. You have to figure out at what point the a/f ratio is correct. To low rpms... you run rich. Higher = lean. There is a sweet spot, you just gotta find it. And tell your dad something, slow people cause accidents!!!
Originally posted by: Thegonagle
Wind resistance increases exponentially with speed, so keeping it at or under 70 or so really helps a lot.
Well it is MPG, so if the miles driven remains constant, then the best MPG would use the least gas.Originally posted by: eakers
i always think about this, driving slower takes less gas but you have to drive for a longer time so at what speed minimizes how much gas you use?
Originally posted by: glugglug
Many will frown on this, and it is pretty rude, but there is a way you can get 100+ mpg.
Tailgate an 18-wheeler. The way the air flows around the truck when it is moving there is a spot a few feet behind the truck where the air is actually moving forward FASTER than the truck is moving to fill the slight vacuum immediately behind it. When you find this spot you will coast along at highway speeds without actually touching the gas pedal.
