Background
I have a fileserver running XP pro in a closet. It's connected via cat5e to a router in the same closet. I connect to through my network to transfer files, etc. as well as windows remote desktop when I need to actually"be at the computer". IOW I have no keybboard, mouse, or monitor connected to it.
Question
I'd like to move the pc and there is no available wire at that location. In doing so I will add a wireless G network adapter.
Note:I already have a wireelss g router hooked up, etc. so that's not an issue.
What is the best way to make the switch from wired to wireless in my situation?
Option 1
Leaving it just as it is, connect the wireless adapter, Connect via RD and configure it. Shutdown, remove the pci NIC. Reboot, and it will work fine as before.
Will it prompt me for my WEP pass key/phrase?
Option 2
Connect monitor, keyboard, mouse and do it the old fashion way.
Option 3
Actually I don't have an option 3.
Any ideas?????
Question
Option 1
Option 2
Option 3
Any ideas?????
