Going from NVidia to ATI causes problems Why?
Turf03
14
I switched out my GeForce 3 in my home PC to a Radeon 9000. It really messed things up. I need some advice. And yes, I am new to this so take it easy.
Please help
Schadenfroh
38,416
4
reinstall windows is what most people say to do. btw, why did you swap them out? there is not much of a differance between a 9000 and a geforce3, as a matter of fact, i think the geforce3 is faster
BFG10K
22,709
3,007
At the very least, go to add/remove programs and uninstall all nVidia related drivers and software.
Mem
21,476
13
Try driver Cleaner 1.5 from here ,read the readme file for instructions on how to use it,it does both Nvidia and ATI drivers.
Tyler
46
Did you also install the drivers for your new card? Cause that would definitely be your troubles if you left your old drivers installed, or forgot to install new ones.
FearoftheNight
5,101
it really annoys me whenever for new drivers people say reinstall windows....that is unacceptable for such a simple operation...or should be....
Schadenfroh
38,416
4
that is the reason nvidia is so popular
gpw11
Woah, do most people reformat just to update their ATI drivers? I just bought my first ATI card, and if that's the deal I'm kind of disappointed.
CraigRT
31,440
only if you run into problems
i didn't
i just pulled out my 4200 after uninstalling the nvidia drivers... and i put in the 9700.. booted it up and installed the drivers, re-installed directx... good to go.
gpw11
Oh, I have no problem with reformating for the initial card switch. I just did that anyways because I felt like cleaning things uo a bit. I was worried about just updating the ATI drivers to newer versions.
Rogozhin
483
naw
it's just fine to delete the registry and ati.dll files and then delete the leftover ati folder "after" you uninstall through control pannel.
rogo
SmuvMoney
28
As long as you're able to clean up the drivers and registry, a reformat/reinstall is not needed. Problems occur is when things are not cleared out correctly or completely.
I just put in a Hercules 9800 Pro last night. I had a Geforce 3 TI 200 in the box before. I uninstalled the drivers and then ran Driver Cleaner in safe mode. I installed the card, installed the latest Catalysts, and went on my way. I will have to reformat my new HD gets here. I plan to install XP on that and leave the other HD for data. That is a valid reason for a reformat/reinstall, but I digress. :)
Viper96720
4,390
My old computer I gave to my sister has nvidia and ati drivers in it. Had a ti-4400 inside and it got messed up. Has a memory artifact problem. I put in an 8500 64MB retail card.
But forgot to remove the nvidia drivers. She hasn't had any problems yet.
