Going from a PC to HDTV
I have a spare PC around that i'd like to hookup to my TV downstairs to watch some movies. Problem is ATM i only have a S-Video connection available. Does anyone have any suggestions on the best way to output video from a PC to a HDTV? I'd like to use composite or DVI connection.
To keep the answer short and simple - use component/vga/dvi/hdmi - any of those will be able to pass hd resolutions
Svideo is limited to 480i standard defintion and is obviously not something you want to use
Go with nvidia if you use the HDTV DVI - they have a nice GUI now to eliminate overscan and I had horrible luck trying to use the base ATI drivers to accomplish the same thing.
Nat
i have the same question. apperanty my 9800 pro has DVI,VGA and SVideo that can output component, need some sort of svido to component adapter. so anyway, can i use a dvi to component adapter and some drivers?
With ATI evidently you need to play around with power strip to get the image correct. I didn't have the patience so I didn't try it. Also, I think that using the component connection, you get to spend $30 for it and play with powerstrip. Does your GF2Ti have DVI? If you TV does too, that would be a much easier route to go.
Nat
Then if your content is not HD and you have no intention of HD in the future, any VGA video card with DVI out should work for SD material.
GT
that's what i thought. DVI out to component cable and use fo drivers(future drivers 4.7 or 4.8 are supposed to support it according to aannd article)
well io have an older rear projection panasonic that has component in only.(im screwed when the hd dvds come out 🙁
