zod96
I am thinking about buying the BenQ XL2420T. I just got a Asus PA248Q which is a E-IPS panel. Well its great but the backlight bleed I do not like. I play BF3 and was really thinking about taking the plunge with 120HZ. How good is the color on the monitor, I know its a TN panel but their are good TN panels and really bad ones how does the Benq compare? Also can you run Displayport at 120hz? And are their any problems with backlight bleed on these monitors, and last but not least what color is the power LED, is it blue? I can return the Asus for a full refund it was #340. The Benq is about $380. I'm just worried about bad color shift and bad backlight bleed
