Going for SLI with a 2nd GTS.
Noema
2,974
nVidia's certified power supply list for SLI 8800GTS mentions the Thermaltake Purepower, so you should be covered.
If you want to stick with Antec they recommend the TruePower Trio 650W.
By the way, keysplayr2003, I just ordered the parts for my rig and it's almost identical to yours (same mobo, CPU and Video Card, only Kingston Hyper X RAM instead of G.Skill)....have tried overclocking your E6420 yet? How's it holding up?
Keysplayr
21,211
50
Great!! You'll love it. Running a moderate o/c of 2.8GHz. This mobo allows you to UNLINK FSB and Memory speeds. So I'm running 1400FSB (350 QDR) and my memory is still at 800. I'll experiment with that later. At stock, I ran 8900 in 3DMark06. I o/c'd the CPU and GPU 2.8 and 600/900 respectively and got just over 11000. Not bad.
Thanks for the list there! However it doesn't mention Thermaltake Purepower, but does mention the Thermaltake Toughpower 650. About 35 bucks more.
