Originally posted by: Zrom999
Remember: always wear your life jacket when in a boat.
True dat!
I would NOT bring any sort of walkman, Laptop, or anything that requires batteries (ommit flashlight and camera).
As for what to bring...
Personally, I like to backpack, so alot of my suggestions will come from that knowledge.  I have been whitewater rafting and canoeing a few times.  I would bring plastic bags.  Stick all of your clothes in a plastic bag, even double bag it if you want.  Do this so your stuff stays dry.  I also stick my sleeping bag inside of a plastic bag.  I do this by sticking the bag inside the stuff sack and then stuffing the sleeping bag.  This way you have those two layers of protection and it is still easy to pack.  As for caonoeing... I would probably bring a cooler.  You won't have ice for all that long, but you could at least keep your food insolated.  It would work well on the boat (you dont have to carry it on your back
).  As for food, Salami is always good.  If you have money, but that expensive freeze dried stuff, I recomend the chilie.  But that stuff is expensive.  You can go to longs and buy stuff much cheeper, and if you are any good with spices you can make it 10x better.  BTW, don't wear deoderant.  You will stink, take a bath in the water (but don't use soap that will harm the waters).  If you use deoderant then the bugs will eat you alive, literaly.  They attract to that stuff like no other.  Speaking of insects, a mosquito head net would be a wise decision.  I don't know how bad they are there, but I know that arround rivers, they can be exceptionaly bad.  They are cheep and very small/light.  But they are worth their weight in gold.  I would suggest something that has a metal ring to hold it away from your face, or get a hat so that it has the same effect.  If it doesn't then it will lie against your skin and won't work.  If you plan on hiking, I would suggest bringing an extra pair of camp shoes, like tennis shoes or sandales.  One of those things that you will just love to have.  Bring a book to read if you think you will have time too.  Make sure that you check everything BEFORE you go on your trip, so you know that you have evrything.  Make a checklist before you pack and then recheck it after.  You don't want to be out there with no rain gear if its expected to rain.
As for what to do, have fun!  Relax and go at a slow pace.  Beign on a river is very relaxing.  If you can find a good spot to stop and jump in off of a rock, go for it and spend some time doing it.  Hopefully you have a good trip.  If you have any more questions, id be happy to answer them.  Just drop me a PM or post here.
Good luck!
