- Aug 9, 2004
- 4,458
- 4
- 81
So my case is pretty sedentary now and I don't need a small, mATX design anymore. Therefore, I'm moving things more towards performance again and am going back to a desktop tower and water cooling
. Here's my current blueprints with a couple of questions, I would like to hear what everyone's thoughts/suggestions/opinions are:
Parts -
Basically going to take the guts out of my current rig and throw them into a new case for now.
Case: Coolermaster 690 II Advanced - I looked through about a hundred cases on Newegg and Amazon and this is the only one that's going to do it. I like that radiators mount up very easily, it's big enough to house everything internally but not huge (20"x20" is about as big as I'd like, so it's good), the airflow is great, and the case looks sexy anyway.
Water cooling:
Radiators - Going with two 2x120mm rads since the case is designed for them. I'm going to put an XSPC RX240 in the bottom and a Swiftech MCR-220 in the top.
Tubing and Fittings - 7/16" Masterkleer over 1/2" Bitspower silver plated barbs, plastic Y fitting (see diagram below)
Pump - MCP350 with XSPC Top
Blocks - Apogee XT on the CPU and MCW80 on the GPU, any reason not to? Also, are the chrome fittings that Swiftech includes of decent quality (to avoid corrosion)? I'm wondering if I should get extra silver barbs just in case.
To explain in case my awesome Paint skills don't show it
P): the pump is suspended in mid-air by the tubing (I've found it's the simplest way to kill vibration noise). The pump goes directly to the CPU block to maintain the highest pressure, then up to the MCR-220, comes down to the GPU block, then down to the RX240, then back to the pump. I also have a fill port off the Y fitting. I guess the big question is can the MCP350 handle this loop, and I don't see why not, as I've had good experience with it in the past when it's coupled with XSPC tops.
Thanks for reading, let me know what you think
-Mr. K6
Parts -
Water cooling:
-Mr. K6
