My Jeep is dying a slow death, so I need to go trade it in and get something decent. Toyota Tacoma, GM Colorado, Chevy S-10, and the Dodgoe Dakota are on the list. I'd like a 4x4 with extended cab, and to hopefully keep it under $20000. Wish me luck 🙂
If you can still find an S-10, you should be able to get it dirt cheap. Same for a Blazer (both have been discontinued). The rest are going to blow your budget all out of whack if you really want an X-cab and 4-wheel drive 😛 .
I guess I'm going to call it off. My wife was OK with it, and then discovered "Oh...wait...you have to PAY for it???!!!", and now the idea suddenly isn't a good one anymore :|
