- Nov 26, 2013
- 6
- 0
- 0
I'm currently looking for a drone so I can install my Go pro Hero 3+ onto it for some photoshooting from the air. I'm thinking of getting a parrot drone but some said it is not reliable. Anybody had any suggestion?
How about the Phantom? I've seen several amazing videos shot with that one, and it seems easy to use. Waterproof too!
Yup, the Phantom is your best bet for an off-the-shelf solution. It's expensive (~$500), but you're paying for an out-of-the-box experience, specifically designed for lifting a GoPro camera. Amazon has it for $479, which is only $179 more than an AR Parrot v2:
http://www.amazon.com/DJI-Phantom-Ae.../dp/B00AGOSQI8
Also remember this is not a toy. It's a $500 piece of equipment that you're going to be strapping a $300 camera to. A lot of people think it's as easy as a video game, but it can be an $800 crash if you're not careful! In some respects it is easy, because you don't have as many skills required to learn as doing an R/C airplane or R/C helicopter, but it still takes some practice.
