go karts how do I get better speed exiting the turns?
iamwiz82
30,772
13
Slow in, fast out. Brake before the turn, then hit the apex and gradually get on the gas
BlackTigers
4,491
Originally posted by: holden j caufield
need to improve my times.
come in high, brake late (right before turn), dive into the corner, and nail it coming back out?
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
Your hair needs to be spikey & you need more flashbacks!!!
ockky
735
Originally posted by: OCguy
Use the star, and hop around the turns with the top right button.
be sure to pull left-right as you slide. the only way you will win against good drivers is if you are able to pull off a Red E
JDub02
6,209
Originally posted by: randay
try losing some weight.
single biggest factor with go-karts. helps increase the power to weight ratio.
and never take your foot off of the gas.
TallBill
46,017
62
Yeah, I lose at go-karting, unless I'm going against a woman and simply outdrive them.
phreaqe
1,204
i am too large for go karts. they dont have the power to get up and stay at speed with me in them. and i only weigh 275.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
You know how you get faster after the first lap or two? You need to suppress your body's senses and learn the limits of the machine. A go kart's center of gravity is so low that the huge relative distance to your head, where the conflicting input is coming from, tells you to slow down way more than is truly necessary when making a turn. Try hunching down and tucking your head while keeping revs up throughout the corner.
*/Ex cart addict with dubious honor of being banned from three tracks/*
Lean L
3,685
?? just take the turn as close to the curve as possible while turning the least... I think those things have a max speed so there's no need for ever taking your foot off the pedal if you want a good time
Miramonti
28,653
100
start wide and cut in to reduce g's, allowing more speed while being under control. Anticipation is key.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Experience talking: You can go a lot faster in the turns than you think. Brake late, accelerate early and though the entire corner if possible. Your foot should be on the gas or brake at all times, no exceptions.
lxskllr
60,218
10,668
I'm curious. Why were you banned?
FoBoT
63,084
15
fobot.com
this is what i did , keep the gas floored ALL the time
use the brakes to get around the corners without crashing, but keep the gas on at the same time as braking
it isn't like you can flip it
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Overly agressive is the most likely suspect.
You start banging into people and become a safety hazard, out you go.
Oct 20, 2005
10,978
44
Jump into the turn then hit the control stick Left -> Right a few times until blue fire is coming out from your wheels, then when you come out of the turn, release the control stick and you will get a boost of speed.
OCGuy
27,224
37
Same reason why I am no longer allowed at the annual Orange County Orgy Festival. :(
So
25,923
17
No way man, everyone knows that the fat characters have terrible acceleration but killer top speeds. Just hit the turns right and get all the powerups.
