Go for WinXP or keep WinMe - for my system... ?
rmd2001
If I have system(see below), should I go for WinXP or should I wait for mature drivers and keep WinMe for now? Usage is: Internet, Gen Apps, Gaming.
Thanks for advice.
Motherboard: Abit KT7-RAID (VIA chipset)
CPU: 1Gh Athlon
IBM 30Gb 75GXP
Sound Blaster Live Value
Plextor CDRW
Toshiba 12X DVD
USR 56K modem
3Com Network Card
GeForce2 GTS - Creative Labs (32Mb)
I hate to be the jerk in the discussion... but why are you asking us this? You are one step ahead of the typical user in that you actually now what hardware is in your box. The next step is to find out if there are drivers available for those parts with XP or if Win2K drivers are compatible. There are thousands of WinXP posts to look through, both here on Anand as well as on Deja News
If you want someone to actually offer you some advice, tell us what you will be using the PC for. In my experience ME only works well with hardware that has ME specific drivers written for it.
There are about 10 of these "should I go to WinXP" threads in this forum a week, it's getting rather tiring.
<< Since you have a SB live I wouldn't upgrade.
You don't mention your memory situation either.
Why? I don't see any problem with SB Live. I don't think he will see one also. If you had Win 2000 and wanted to upgraded to Win XP then I would probably say up to you but from Win ME to Win XP is definetely. You will see better performance.
My system is way slower that you and have XP installed on it. It never crash since the first time I installed it.
One more thing that I forgot is once you install XP, go to Windows Update. There's an update for Sound Blaster.
So go ahead and install XP. You won't regret it at all.
Darno
<< Since you have a SB live I wouldn't upgrade. >>
I haven't had any trouble with my SB live. Of course, I haven't done anything stupid by trying to load anything except the default drivers included with XP. I have used this SB Live in both an Intel BX and AMD 761/Via 686 mainboard, and XP has worked perfect.
Xp, no doubt,
EVEN... IF.. and i mean IF XP sucked... it could never possible suck as bad as Windows Me.. .it will be a blessing from god once you get to Windows Xp.. and experience some true stability! 😛 Good lUck
