GnatBox Light Problem
Nov 20, 1999
34
I am trying to set up GnatBox Light on a 386 with a 56K modem on COM4.
When I run IE on another machine on the network, the 386 tries to dial out,
but I get these messages. (read bottom to top for chronological order):
Dec 28 02:31:53 PPP: Phase: bundle: Dead
Dec 28 02:31:53 PPP: Phase: deflink: hangup -> closed
Dec 28 02:31:53 PPP: Phase: total 0 bytes/sec, peak 0 bytes/sec on Thu Dec
28 02:31:53 2000
Dec 28 02:31:53 PPP: Phase: deflink: : 0 packets in, 0 packets out
Dec 28 02:31:53 PPP: Phase: deflink: Connect time: 11 secs: 0 octets in, 0
octets out
Dec 28 02:31:53 PPP: Phase: deflink: Disconnected!
Dec 28 02:31:52 PPP: Phase: deflink: dial -> hangup
Dec 28 02:31:52 PPP: Warning: Chat script failed
Dec 28 02:31:52 PPP: Chat: Expect timeout
Dec 28 02:31:47 PPP: Chat: Expect(5): OK
Dec 28 02:31:47 PPP: Chat: Send: AT^M
Dec 28 02:31:47 PPP: Chat: Expect timeout
Dec 28 02:31:42 PPP: Chat: Expect(5): OK
Dec 28 02:31:42 PPP: Chat: Send: ATZ^M
Dec 28 02:31:42 PPP: Chat: deflink: Dial attempt 1 of 1
Dec 28 02:31:42 PPP: Chat: Phone: 2321152
Dec 28 02:31:42 PPP: Phase: deflink: opening -> dial
Dec 28 02:31:42 PPP: Phase: deflink: Connected!
Dec 28 02:31:42 PPP: Phase: deflink: closed -> opening
Dec 28 02:31:42 PPP: Phase: bundle: Establish
It appears that Chat isn't hearing any response from the modem for the AT or
ATZ commands. If I remove these commands from the init string, the modem
dials the server and then times out waiting for connect. When I go to dos
and use a terminal to dial my ISP, there is a connect sign. It appears that
chat isn't seeing any of the modem's responses. The modem responses are on
by default and ATZ restores the modem to default config. What should I do?
Thanks for the help.
