GMail Drive shell extension
hevnsnt
http://www.viksoe.dk/code/gmail.htm
GMail Drive is a Shell Namespace Extension that creates a virtual filesystem around your Google GMail account, allowing you to use GMail as a storage medium.
GMail Drive creates a virtual filesystem on top of your Google GMail account and enables you to save and retrieve files stored on your GMail account directly from inside Windows Explorer. GMail Drive literally adds a new drive to your computer under the My Computer folder, where you can create new folders, copy and drag'n'drop files to.
Ever since Google started to offer users a GMail e-mail account, which includes storage space of a 1000 megabytes, you have had plenty of storage space but not a lot to fill it up with. With GMail Drive you can easily copy files to your GMail account and retrieve them again.
When you create a new file using GMail Drive, it generates an e-mail and posts it to your account. The e-mail appears in your normal Inbox folder, and the file is attached as an e-mail attachment. GMail Drive periodically checks your mail account (using the GMail search function) to see if new files have arrived and to rebuild the directory structures. But basically GMail Drive acts as any other hard-drive installed on your computer.
You can copy files to and from the GMail Drive folder simply by using drag'n'drop like you're used to with the normal Explorer folders.
Because the GMail files will clutter up your Inbox folder, you may wish to create a filter in GMail to automatically move the files (prefixed with the GMAILFS letters) to your archived mail folder.
Please note that GMail Drive is still an experimental tool. There's still a number of limitations of the file-system (such as total filename size must be less than 40 characters), and it doesn't make full use of the secure internet protocols available.
If anyone needs a gmail account to test with, pm me!
Pretty cool. It adds and deletes no problem. Just that it saves my files as a .bin format.. maybe it's just with zips.
Originally posted by: ElFenix
No spyware right?
Like you have to worry about people being interested in you.
Well you obviously have your hand down your pants over my posts.
Yeah, I'm stokin' all inch and a half to you.
damn! an inch and a half! 🙁
Everyone exaggerates a little bit, don't they?
No spyware right?
Ya but not by over an inch.
No spyware right?
Oh... Damn.
Originally posted by: hevnsnt
hey bitches get out of my thread!
lol sorry
this brings an interesting point tho...if they've taken over the thread...wouldn't it be their thread then, ergo you lose the right to oust them?
What do you expect? You posted about software in a non-software related forum. 😕
I only post where you will be.. 🙂 Since you gave up on the software forum.. I had no choice. 😉
I haven't given up on the software forum. I just don't thread crap as much there. 😛
