GM recalls about 33,700 vehicles to fix software issue
dmcowen674
54,889
47
www.alienbabeltech.com
3-20-2013
http://news.yahoo.com/gm-recalls-33...RhaWQDBHBzdGNhdANob21lBHB0A3NlY3Rpb25z;_ylv=3
General Motors Co is recalling about 33,700 model-year 2013 Buick LaCrosse sedans and Cadillac SRX crossover vehicles globally to address a potential software problem that could increase the risk of a crash.
GM said the problem may cause the transmission to unexpectedly slip from manual to automatic mode.
Dealers will reprogram the transmission control module free of charge.
dmcowen674
54,889
47
I'm sorry but I think it is fucking retarded that a vehicle can potentially crash due to a software issue.
I just had to pay $1,000 on my car because it would just die in the middle of the road.
It took three trips to the shop to find it was Crankshaft Position Sensor causing the problem.
Put back cam lobes.
This sensor shit is just that, shit.
boomerang
18,883
641
Put the blame where it belongs. You wanted safer cars that got better gas mileage and produced less emissions. Your demands dictated what the modern automobile is today. We'd all still have carburetors but for your demands.
PottedMeat
12,363
475
leave this part out?
The U.S. automaker said there are no reports of crashes or injuries related to the issue.
would you rather they not fix the issue or charge you for it?
BUTCH1
20,433
1,769
Put back cam lobes.
Co-worker just had that same problem, 2001 Dodge stratus. All cars have cam lobes, otherwise the valves would never open..
Zargon
12,218
Put back cam lobes.
I guarentee you the cam has lobes, the CPS is for variable valve timing, im surprised it dies when it screws up, my wifes car will just run slow as it regresses all timing to fail safes
LTC8K6
28,520
1,576
Several computers and a network controller are now involved just to make your turn signals blink...
foghorn67
11,883
63
Put back cam lobes.
How would a car burn efficiently without o2 sensors?
Don't be a manchild.
Doppel
13,306
Damn, is there no issue you're wildly ignorant on but nonetheless have a strong opinion about? Software controls the throttle in modern cars, the brakes, and increasingly the steering.
Yeah, let's get rid of sensors in cars! Freaking genius. While we're at it, let's do away with air bags, stability control, everything.
phucheneh
7,306
wut.
Crank sensor is engine speed, cam sensor is engine position. You need both, with or without VVT. The simplest VVT just adds movable cam gear(s) and a solenoid that actuates each with engine oil pressure.
nerp
9,865
105
You can do like in small airplanes and manually control the fuel/air mixture. Would not be a hassle what so ever.
Yes because masturbating a little choke pulley and finessing the gas like you're trying to massage an angry cat on its belly just to get it started is the hallmark of pleasurable driving.
Doppel
13,306
Exactly, it wouldn't be a problem at all.
phucheneh
7,306
...you guys are aware of how frequent and minute the fuel trim changes are on a modern car, right?
Allow me to demonstrate with a one second sample of O2 sensor data:
RICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEANRICHLEAN
LTC8K6
28,520
1,576
Well, the carburetors of my youth seemed to work okay.
Of course they were less efficient, and the engine gave up on you at altitude, and they vapor locked, and they froze up, and they stumbled if you lifted suddenly, and they flooded the engine sometimes, but hey... :p
foghorn67
11,883
63
That's what we call a good time.
HeXen
7,838
39
Some cars from the 70's and 80's get just as good gas mileage. Safer cars imo were safer when they were made out of thick, heavy steel, not this mish mash of plastics and aluminum foil crap forcing them to put in all this safety sensor and vagina soft impact cabs..etc.
I had a 64 Chevelle SS one time that had been T boned hard and only had a dent in the lower door panel. You could even stand on the roof of the car and it would never buckle or bend.
