I think you are referring to the GlobalWin WBK 38, but I am not certain. The Thermalright SK-6 is supposed to be able to do this as well, so if it isn't the WBK, then get the SK-6.
I mounted a 92mm Fan on my WBK-38... Just had to bend the clips a little and attach them to the fan grill on the bottom of my Panaflo 92mm.. Heres a few pics:
uhm temps are a little higher so far, bout 2 degrees celcius above where i was runnin at b4. Although it might be attributed to the wire loom i had to move around blocking the front intake fan. So who knows.. The Fan i replaced it with was the Panaflo 92mm Low Speed fan..... Thanks...
