- Oct 23, 2000
- 9,200
- 765
- 126
Granted, this card is old. But the 280X still works very well for some distributed computing projects that make use of its double precision calculations.
Unfortunately, this card has a problem and I don't know how to fix it.
Under full load from the MilkyWay@home distributed computing project, the card spikes up to 97C frequently, which causes a driver crash that reverts the card back to 501Mhz, making it very slow and inefficient, and requires a complete reinstall of the drivers to get it working again at anything more than 501Mhz. If I use MSI Afterburner to manually force the GPU to 700Mhz and RAM to 1300Mhz (stock is 1000/1500), then the card will run steadily, albeit a lot slower than it should. It overheats and crashes at anything higher than 700Mhz. It still gets quite hot at 700Mhz, but not hot enough to crash.
This is in a room with a very cool 20-22C ambient temperature, and a case with excellent cooling. The Ryzen 9 3900X in the same case, also under full load from DC projects, stays well below 70C. A single fan GTX 1060 also runs cool in the same case at 100% load. For testing purposes, I removed the side panel from the case and pointed a very high volume desk fan directly at the GPU and the temperatures only dropped by a couple of degrees at most and sometimes there was no difference at all, so it seems to be getting plenty of ventilation in the case.
All three of the GPUs fans seem to be spinning well and the heat sinks are clean. I've used a custom fan curve in MSI Afterburner to force the fans to 100% when the card gets over 65C, and I have replaced the thermal paste with good quality Noctua NT-H1. And I even pulled it out and replaced the good stuff again just to make sure it was applied well.
The only thing I've noticed that seems like a potential fix is that the thermal pads on the VRM and RAM chips are worn and dirty, but I don't know if they are actually overheating or not since the card doesn't appear to have separate temperature sensors for the GPU and the VRMs. I'd be happy to try replacing the pads if it will help, but don't know what product would be best to use.
I'd appreciate any suggestions you can give to help me get this card working properly again!
*edited to add a little more detail to the post*
