I'm helping a friend set up a machine with this board, and we've run in to some problems. Whenever a serial ATA drive (or some USB devices it seems) is connected to it, the computer will freeze during the Windows XP setup at "Setup is starting Windows". I've tried pretty much everything at this point -- removed any unnecessary components, underclocked the CPU and memory, disabled integrated peripherals in the BIOS, moved the memory sticks around, and even tried a different Windows XP disc. The exact system specifications are as follows:
Core 2 Duo E6400
Gigabyte P965 DS3 Rev 3.3 with the latest F10 BIOS
GeForce 7600 GS
2GB of Kingston DDR2-667 value RAM
Corsair 520HX PSU
That's all that's in the system right now, I've removed everything else that wasn't absolutely essential. I'm not really sure what to try next. There's a Microsoft knowledge base article here that says that the problem might be caused by setup being unable to detect some hardware in the computer, but I've already tried everything that it suggests (other than the last two options, but that really should not be necessary). It also says that if pressing CTRL+ALT+DEL works during that phase of the setup process, it's probably not hung -- but it does not. We may try returning the board tomorrow assuming the store will take it back if I can't find a solution, but I'm not optimistic at this point. Anyone have any ideas as to what might be the cause of this?
Thanks!
Core 2 Duo E6400
GeForce 7600 GS
Corsair 520HX PSU
Thanks!
