Gigabyte P67A-UD3-B3 has problems with turning on after going into sleep
996GT2
My system often has problems recovering from sleep, especially if it has been in sleep for more than a few hours. I am using the P67A-UD3-B3 motherboard with the newest F3 BIOS. My system passes 12+ hours each of Prime95 Blend, LinX, and Memtest86+, so I am relatively sure that it is stable. However, when I try to turn on the computer from sleep, it sometimes will not turn on at all and will go into an endless loop of turning off, turning on for a few seconds, turning off again, turning on again for a few seconds, and so on.
The only way to fix this issue is to reset CMOS. But a few days later, the problem will inevitably happen again. This is my second P67A-UD3 board (my first one was RMA'd for a newer B3 one due to the SATA bug). The first P67A-UD3 I had also had the exact same issue with coming out of sleep, even after multiple BIOS updates and tweaks.
Can anyone shed some light on this issue?
Here are my system specs for reference:
Core i5-2500K @ 4.4 GHz (1.292v @ 100% load in Windows)
2x4GB DDR3-1333
Intel x-25M G2 80GB (newest 02M3 Firmware)-boot drive
Hitachi Deskstar 1TB 7200.C
WD 500GB 7200 RPM
Galaxy GTX 460 GC
Cooler Master Hyper 212+
Corsair GS 600 PSU
Windows 7 x64 Professional with latest updates
I am having the same problem doing this on my Asus motherboard. I think this is a common issue on all P67 motherboards. Some combination of settings is causing havok trying to sleep.
