Gigabyte P35-DS3P and Cooling Installation
frankbo
22
I've searched through the forum for info, but I wanted to post briefly just in case there's someone with this board (or something similar) who's willing to share. I'm still trying to figure out which HS/fan to purchase, and I thought it might be a good idea to know if there's any whose lateral dimensions make installation challenging on this model mobo.
Though I hope anyone with experience on any Gigabyte mobo might share their experience. Thanks!
LOUISSSSS
8,771
58
the tuniq fits the length of it perfectly, mounting the Tuniq with a front-rear orientation, the edge of it comes to the edge of the motherboard perfectly, giving you virtually no problems with fitting in your case.
by comparison, if u use a TRUE in a front-rear orientation the edge of the heatsink will stick out over the motherboard so make sure there is nothing else in the way.
those are the the two most talked about heatsinks on the market right now after the ACF7P and they will DEF fit on your motherboard and case
