I just bought a new Gigabyte P35-DS3L and case. My PSU is less than a year old and is of good quality and has been running fine. I connect everything to my new setup, and at first it doesn't boot. The fans spin for 2 or 3 seconds and then it shuts down, nothing on the screen. I try turning the computer on and off a few times and the same thing happened.
So I unplug my PSU and make sure all the power cables are securely connected. I don't notice anything, but the next time I start the machine--voila--it boots and everything posts; ram, harddrives, cdrom drives, etc., but I also notice that my heatsink fan isn't spinning.
I check the BIOS and see my CPU temp warming up.
I shut down the computer and reconnect my heatsink fan to another connector, like SYSFAN_2, and the heatsink fan starts spinning.
So is the CPU_FAN connector on my mobo fried? Is there something I'm doing wrong or is there anything I can do to revive it? The heatsink is also new. It's a Freezer 7 Pro.
Thanks
Thanks
