GIgabyte P35 DS3L auto and manual voltage
tornadog
1,222
I have the Rev 2.0 board and running the latest F9b bios. When I set my fsb to 433 and voltage to auto, it boots up and runs fine. But when I change it to manual and select normal for the cpu voltage, it gives me a bsod during the OS loading. What does auto do differently from my normal voltage setting. only way i can get it to boot properly is to raise the cpu voltage to 1.4V. But at auto everything is fine and even orthos runs without failure for over 2 hrs.
VirtualLarry
56,587
10,225
"Auto" CPU voltage often scales upwards along with your FSB setting. However, every CPU is different, and generally, the BIOS overvolts compared to what is required, when set on auto. I would set the CPU voltage manually.
