- Mar 8, 2005
- 128
- 0
- 0
To all of those who own a Gigabyte NF4 motherboard, do any of you have any problems installing heatsinks that must use their own mounting bracket because of a small raised IC chip near the socket?
Right now, I am using a Zalman 7000 HSF which doesn't need any mounting brackets whatsoever - it screws directly onto the backplate ( Gigabyte GAK8N Ultra-SLI )
However, when I tried to install a Coolermaster Hyper 6 HSF, I've discovered that there is a small raised IC chip near the socket and prevents the mounting bracket that came with the Hyper 6 from lying completely flat around the socket. The mounting bracket that came with the gigabyte motherboard has 4 small feet which raises the bracket above the IC chip. But most 3rd party mounting brackets have a completely flat bottom which presents a big problem.
Here's a picture of what I'm talking about :
Raised IC Chip : Link to picture.
Bracket with 4 feets that came with the motherboard. Link to picture.
Has anyone else experience any similar problems?
The heatsink I really would like to use is Scythe Ninja SCNJ-1000. It too needs its own mounting bracket for use on socket 939 motherboards.
Thanks much in advance.
