Gigabyte h55n-usb3... Where do I connect h50 pump??
Johnson184
I've used up the 3pin CPU fan slot with the fan mounted above the h50 radiator. Where do I plug in the h50 pump??
Plug it into the power or chassis fan connector. Never use a header controlled by your BIOS. If your BIOS has this feature turn it off as the pump needs 12V all time time. It's very quiet so reducing the voltage makes little acoustic difference however even a slight reduction in pump voltage will reduce cooling significantly!
