Gigabyte Geforce 6600GT Silent-Pipe II
Operandi
Link
I'm putting this here rather then video due to it's passive heatsink. It looks like a fairly impressive design. Hopefully looks aren't deceiving and Gigabyte learned their lesson from their previous horrible passive line.
suszterpatt
927
There are more efficient aftermarket passive VGA coolers out there (I'm looking at you, Thermaltake Schooner). This looks like a very bad compromise between price and cooling power.
Operandi
First; this is a stock cooling solution, comparing it to any aftermarket cooler doesn?t make much sense. Second; since both price and performance are unknown so you're making baseless assumptions.
Assuming that it's put together correctly this looks like a very good solution for those that don't feel comfortable with aftermarket GPU heatsinks.
Shadowknight
3,959
I've heard that a lot of the gigabyte coolers come with crappily applied thermalpaste, so you'll probably get better temps if you take the cooler off and reapply the TIM.
JEDIYoda
33,986
3,321
I Love Gigabyte Video cards!! never had any issues with thermal paste or theremal pads!!
suszterpatt
927
Assumptions yes, but not baseless. Larger/more heatsinks tend to give better cooling performance, and you can't put much more fins on a cooler than the Schooner does. And since most active aftermarket coolers are cheaper than passive ones, there's no reason to assume that a card that has such passive cooling out of the box is cheaper than if it had active. Plus it's a rarity, which means they can easily get away with charging a bit of extra for it.
You're right though that this is a convenient solution for silent freaks who don't feel like messing around with their vid cards.
lifeguard1999
2,323
<a target=_blank class=ftalternatingbarlinklarge href="http://www.insanetek.com/review.php?id=217">Insanetek Review of Gigabyte GeForce 6600 GT Silentpipe II
</a>
