Originally posted by: danielbeper
Hello, I was able to fix it in the end, but it was tricky, after upgrading to SP2 and all patches, then I had to remove realtek and the WDN software installed, including KB888111xpsp2 update.
Once I removed all this, rebooted my system and installed in the following order (strictly, other order did not work for me), the kb835221, then kb888111xpsp2, then sp26334, then WDN_R172A, and at the very end, realtek drivers... this was the only way it worked for me............. what a headache...took me 3 days to reach this solution ....
Hi guys, I was surfing looking for solutions to this problem, because just yesterday I assembled a computer with Motherboard GA-P35-DS3R, Processor Q6600, ATI Radeon X300 video card, 2GB RAM DDR2 667, well unfortunately I ran into the same issue as you did, with Windows XP, I updated to SP2 and all security, software, hardware patches available in windows update site, still can not install the Realtek audio drivers.
Has anyone of you found a solution yet, or do you still have the same problem?
Does going to Vista OS solve this issue?
