GIGABYTE GA-P35-DS3L power fan?
UTFan81
What exactly is the power fan connector on this mobo for? There is sysfan 1 + 2, and pwr fan. One of my case fans only has 3 pins and sysfan 2 uses 4 so should I plug my 2nd system fan into the power fan? Thanks.
bump. well I plugged my second case fan into it for the hell of it and it seems to be running fine. I can even monitor the speed.
Larry is right, it's for PSUs that have a 3-pin connector so you can monitor their fan speed.
Edit: Also, you should be able to plug your 3-pin case fan into the sysfan2 header.
thanks I did that.
