On the motherboard there is two Firewire connetors, one for 1384 and one for 1384b. The 1384b is used for the rear connector included in with the motherboard. I'm trying to connect the Front 1394 port that came with the case but I've ecounted a problem. The cable that came with the cae has pin 9 or 10 blacked out. The MB has pin number 7 blacked out. The cable is marked saying Intel Spec. 1394 Cable. Does anyone have a solution for connecting the front Firewire port to the MB? Any help will be greatly appriciated.
