- Jun 21, 2005
- 12,087
- 2,282
- 126
Okay just got the combo (E6400 retail week 24). Updated bios to F4C. Booted fine with 2 sticks of OCZ Gold PC2-6400 5-5-5-12 1GB(2x512mb) DDR2.
When I try to install windows with my USB DVD drive, it reads really slow. Can a USB DVD drive go to PIO mode. I switched over to an IDE DVD and I think it's fine now. Also, is there any place in bios to check whether a hard drive or cd drive is in DMA or PIO mode??
Does anyone else get some weird starting routines...like it'll start fine sometimes but other times it'll start then shut off immediately...sometimes when I save and exit out of the BIOS it shuts off.
Also, is the PCI (not PCI-e) bus locked at 33mhz?? I wanna overclock but I got a SCSI drive on a PCI controller. I see a setting to lock the PCI-e bus but not the PCI bus.
I'm installing windows now...I'll post my OC results a little later. THanks for any help.
Update 1
Okay, fired it up at all stock voltages except CPU voltage which is set to 1.400v (stock 1.325) and through Gigabyte easytune I have it running at 400x8=3.2GHz. Currently running SP2004 Orthos(like Prime95) to check for stability.
BUT, are the temperatured reported in Bios and Easytune correct?? I was getting about 48-52 degrees at idle in bios and about 66-68 degrees at load in Easytune. I'm running a Thermaltake Big Typhoon. So are the temperatures off??
Update2
I got to 3.2GHz SP2004 stable at only 1.35v from 1.325 stock. Mmmm...loving this processor. And temperatures stay around 60 load degrees now. If the temp. readings are correct, they skyrocket even if you add a small amount of voltage.
Update 1
Update2
