- May 15, 2007
- 2
- 0
- 0
Hi all -
What combination of BIOS settings do I change to get the CPU fan to run the
speeds it needs to run.
Right now it is always on 100%.
When I first built this thing, it ran at variable speed.
Then I played with various settings to underclock my CPU (in order to underclock the RAM because it was not running stable) and another thing I did is run some stress test software in Windows called "OCCT" and since then the fan has been running 100% speed at all times.
I *think* I've tried pretty much every combination in BIOS on settings that refer to the fan but not for sure.
Thanks for any advice!
Oh I'm running latest BIOS from Gigabyte; version 11.
Scott
Scott
