Gigabyte 9600 pro dual monitor...?
Hey everyone...I'm wonder if the gigabyte 9600 pro supports dual monitors....I'm not sure if certain manufaturers (ie, gigabyte vs. asus) have different support for this feature or not...?
Is anyone out there running a gigabyte 9600 pro with duals mons? or anyone with any other 9600 pro?
Additionally, if you are i wanted to confirm the ue of a dvi-i to vga convertor is what i need to hook up a second VGA monitor.....The ATI site does mention the 9600 pro has dvi-i output, however when i navigate over to the actual dvi-i adapter, it doesn't list the 9600 as a compatible item for the adapter...
Could someone clarify this for me? or just point me to where I could find out?
Thank you in advance!
All 9600Pros and 9600XTs *should* support dual monitors.
I don't see a Gigabyte 9600Pro (at least on Newegg), just a 9600SE -- which does NOT support dual monitors -- and a 9600XT (which does).
Also, that link doesn't work -- but are you looking at the cable for the AIW cards?
Edit: I found the "DVI-I TO VGA ADAPTER" on their site; that is almost certainly the part you need (though it should be included with the card if it supports it). It doesn't list the 9600-series cards on compatibility list, but ATI's online store is hardly complete or correct.
