GigaByte 8KNXP, RAID problem
JizJizJiz
I have the 8KNXP board and under the ?Advanced? setting in the CMOS, the ?SCSI Boot Order? devices are not constant. It should always have the GigaRAID, Intel SATA RAID, and Silicon SATA RAID. However, sometimes when I boot up, I get none, other times I get only the Intel SATA RAID, and yet other times I get all three. I am running BIOS version F5.
Thanks in advance,
I have the same problem, with bootup.
I beleive you have all the drivers loaded to enable settings, but it dosen't always show up.
Gigabyte needs to fix this.
I played around with it setting all to diabled and then reenabling them and they work fine now. Boots with all 3 showing now.
I wonder if the dual bios has anything to do with it.
It's set at auto by default, you may want to switch it.
