i get a constant BEEEEEP from my motherboard because it thinks the CPU fan has failed, although it is plugged into the CPU_FAN 3 pin on the motherboard, and works fine, but in bios it hows the RPMS as 0.
So you need to go to Vantecs' site and see if you can find out if those TMD fans have rpm monitoring. If you can't find it on the site, send an email to their tech support.
