rookie1010
I was wondering if anyone out there had problems with the gigabyte 81875 ultra mobo. At times the ethernet port uninstalls itself and then no matter how many times i try to install the driver, it says there is a problem with the installation of the software driver.
i stuck in a ethernet card to solve the issue. so my onboard ethernet port was sitting idle.
now recently the usb port had some issue, one fine day when i started my machine, it said something about new hardware and that the USB port had been found and where would i like to install the software from, i think for hooking up USB 1.0 devices it requires no software. since my keyboard and mouse which are wireless and hooked to the PC using the USB have no problem. i think it is USB2.0 which requires some additional driver which might be the problem
if you guys have seen the same and know what the solution is, please let me know.
