Gigabyte 7N400 Pro 2 Voltage Settings
mato7742
230
The problem I am having is that my AMD 2500+'s core voltage is registering 1.70-1.74 on standard settings 11x166. Shouldn't the voltage be down around 1.65 for this processor? I am using the latest BIOS upgrade (F5) available from gigabyte.
On the review of the 7N400 pro it was stated that there are voltage settings in the BIOS adjustable in 0.25 increments. I can't find them on the Pro 2. Even after using gigabytes CTRL-F1 trick (why not just put these settings right up front!!??) If the settings on voltage are not available on this board, why did they change from the 7N400 Pro.
Any thoughts? I have searched all all nforce and gigabyte forums and have seen a lot of posts on temp but none on voltage. I know there is a setting to increase the voltage by 5%, 7.5%, and 10%. Not very helpful if the voltage is too high to begin with.
TGHI
227
Yes...the 7N400 is overvolted...you're right - the normal voltage settings for an AMD is 1.65V - but the 7N400 runs at 1.71...why...I don't know.
TGHI
