I wasn't going to watercool but then I got the NewEgg blackFriday rebate deal on this thing so I couldn't pass it up for 71 bucks. I got it up and running in 30min and so far it's working out great. I'm wondering if anyone else has this case and any tips on using it. I poured about 1.5 bottles, or 900mL of the included coolant. I got pretty much all of the bubbles out of the tubing, but there's some bubble in the reservior. Does this matter?
It does have some issue as far as I can see. Does anyone get annoyed by the flow indicator (that swirling fan above the fluid level window). It creates a minor but annoying racketing sound as it rotates. Is it just my case, or does the sound also appear in yours? This is most obvious in silent mode where everything's quiet. Once you crank the pump up to normal, it more or less becomes blended in by pump noise.
I poured a bottle and half of the coolant in this. It's about topped off. I still have some bubbles in the reservior (and the flow indicator, which may be contributing to the noise above. How do I get rid of all bubbles?
Also it's not that much more effective than my aircooled CoolerMaster HyperTX2 (which is $0 AR). It's definitely better for load temp, but my overclock stability has not improved much. It could just be the processor though.
