I'm kind of confused about this and haven't been able to find a real good explanation online.
I have 1 pc now that has a regular 100mbps ethernet port, as well as a second gigabit ethernet port.
I'm building a 2nd pc now that has dual gigabit ethernet ports.
I just have a normal 100mbps router.
What I'd like to do is have both PCs hooked up to the router to access the internet as normal. But I'd also like to be able to hook the 2 PCs up directly to each other to make use of the faster gigabit speeds, as one of the pcs acts as a media/file server. I don't really need any other PCs to use gigabit speeds, just the 2 PCs here in question.
Is what I want to accomplish as simple as just running a ethernet cable between to the 2 PCs via the gigabit ports? Would it magically know to use the gigabit connection to transfer files and not use the workgroup connection over the router? Or do I need a switch for this. Or what? I know what I want to do, I just don't know enough about how to accomplish it.
