TheInternal
Hey all,
I'm working on a system I slapped together around an old AMD Barton 3000+ with a Gigabyte GA-7N400 Pro (nforce 2 based) motherboard and have been trying to tackle problems in some sort of sequence of importance.
I've solved the CPU not being detected properly (a little switch by the north-bridge for the FSB speed).
I may have solved my random blue screening (ran the RAM through over 30 passes and it tested good) by doing a minor over volt (fingers crossed!), but I'm still having issues with the on-board network adapter.
Every time I start up windows XP MCE 2005 (fully updated/patched/SP3), my network adapter can't connect to the internet. I've tried reinstalling a few times (and now have it showing that it's the #3 adapter despite it being the only adapter. Is there some kind of ghosting issue I need to resolve / can't access?), but that didn't fix it. Now, to make the internets work, I have to disable then re-enable the adapter after I boot up. A command prompt release / renew doesn't cut it.
After I solve the networking issue, it's figuring out how to cold boot the machine and have it recognize my Maxtor Maxline III 300 GB SATA drive without having to hot plug it >.< (it reboots fine, just requires the hot plugging on cold boot like it did on an old MSI board until a BIOS fix was released).
