Ghost armor damaged my iphone 5
Discussion in 'Mobile Devices & Gadgets' started by zaydq, Feb 24, 2013.
  1. zaydq
    zaydq Senior member
    Jul 8, 2012
    782
    Update... Seeing apple today. Once they deem the cause is water damage is when ghost armor will replace the device. Starting to sound like a run around.
  2. 3chordcharlie
    3chordcharlie Diamond Member
    Mar 30, 2004
    9,860
    Every company, ever, has some sort of 'we do not assume responsibility' document. That doesn't hold much water legally. Even with a signature on a contract, waivers are not ironclad, depending on what responsibility is being signed away. Negligence, for one, often cannot be waived.
  3. bigrash
    bigrash Lifer
    Feb 20, 2001
    17,614
    I feel the same way. You spend all that money and then just waste it.
  4. zaydq
    zaydq Senior member
    Jul 8, 2012
    782
    Just an update. Apple decided to replace the device. No proof of water damage despite my story. I still know that the ghost armor application was the reason. Lesson learned, i'll roll naked.
  5. Ashenor
    Ashenor Golden Member
    May 9, 2012
    1,227
    Ya i have not put anything on my last 6 phone's and have had zero issues.
  6. MrX8503
    MrX8503 Diamond Member
    Oct 23, 2005
    4,531
    Just use a dry screen protector. I've been using them for years. I don't know why anyone bothers with wet application screen protectors.
  7. Chocu1a
    Chocu1a Golden Member
    Jun 24, 2009
    1,289
    9
    Thin TPU case & regular cheapo screen protector. No fuss or worries.
    tpu adds protection without bulk. cheapo screen protector is cheap & easily replaceable.
  8. gorcorps
    gorcorps aka Brandon
    Jul 18, 2004
    29,674
    155
    If the wet apply protectors didn't have such a sticky texture I would still use them. On a touch screen where swiping is a necessity they aren't great, but IMO the application is superior. The dry ones are okay, but the risk of lint and bubbles is higher and there's little you can do about it once it's there. With the wet application you have a number of seconds where you can slide the protector around the screen to properly position it, and then find any lint or bubbles. I've never had an issue with the wet app ones, but sometimes have issues with lint sneaking in despite applying in a humid room and with a lint free cloth.
  9. jacktesterson
    jacktesterson Diamond Member
    Sep 28, 2001
    5,490
    I don't like screen protectors even though I've used them lots of times on phones I knew I wouldn't keep for long (to keep resell up)
    I'm using a think (*EDIT: thin) leather flip case on my S3 with no screen protector currently.
    #34 jacktesterson, Feb 28, 2013
  10. MrX8503
    Oct 23, 2005
    4,531
    Dry is definitely harder, but its possible. Mine feels like glass, invisible, and no lint.
    If you do get lint, the trick is to wrap both index fingers with clear tape. Use one finger tape to raise the protector back up and use the other finger tape to capture lint underneath.
  11. lopri
    lopri Elite Member
    Jul 27, 2002
    11,990
    62
    Glad to hear that you resolved the issue satisfactorily. I think Ghost-Armor should train their technicians more adequately. I do like their products but it seems like the end results vary per who did the job.
  12. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    Thats pretty cool of Apple after you told them how it got damaged. :thumbsup:
  13. s44
    s44 Diamond Member
    Oct 13, 2006
    9,339
    Just give your phone a dedicated pocket and forget the screen protector.
  14. zaydq
    zaydq Senior member
    Jul 8, 2012
    782
    I've given my phone its own private pocket :).
    I thought it was cool of apple, but in reality, they just didn't find any indication that water was the cause, hence, despite my story, they just said it was a fault in the device. Had one of the water markers been triggered, i'm sure it wouldn't have been Apple replacing it.
  15. MrX8503
    Oct 23, 2005
    4,531
    You never know what Apple might replace, so it never hurts to try. Apple has known to do repairs even out of warranty.
  16. RampantAndroid
    RampantAndroid Diamond Member
    Jun 27, 2004
    6,587
    They replaced my ipad2 when I'd dropped it and damaged the lock switch....clearly my fault and I admitted it was. They surprise sometimes, and it's why I still buy some of their stuff even if I hate them as a company :)
