I am completely new to this and have been reading the last couple hours trying to figure this out without luck. Did a search here and read the radified guide to Ghost but still don't understand a few things.
Ghost 7, just the ghost.exe file, came with my motherboard (8RDA+). The manual is good for the actual process of creating and restoring but either I missed some details or it didn't contain them because the ghost.exe does not work in Windows XP Pro and I don't have a floppy drive. The manual contains detailed instructions on creating a recover floppy and recover cd but I am guessing some of the things it tells you to add you can't to just boot into DOS as it states it will automatically backup or restore.
So I need a very simple step by step of what I need to make a bootable cd. Can I just burn the files using Windows XP built in cd burning or is a bootable cd different then just burning some files?
Sounds like I need:
Command.com
IO.sys
MSDOS.sys
Mscdex.exe
ghost.exe
oakcdrom.sys
config.sys (device=oakcdrom.sys /d:idecd001)
autoexec.bat (mscdex.exe /d:idecd001 /l:z)
What about the lines this manual says to add to the autoexec file or is that only for automatic restoration/backup (ghost.exe clone, mode=load, src=z:\orignal.gho, dst=1 -sure -rb or ghost.exe clone, mode=pload, src=d:\orignal.gho:2, dst=1:1 -fx -sure -rb or ghost -clone, mode=pdump, src=1:1, dst=d:\recent.gho -fx -sure -rb or ghost.exe -clone, mode=pload, src=d:\original.gho, dst=1:1 -fx -sure -rb) ?
So I need the exact files I need for the bootable cd and then how to actually create it (unless I can just use the XP built in cd burning). Then I just boot using the cd and follow the manual to make the backup?
If I am booting using a cd then I guess I can't backup the image directly to the cd since it will be occupied so I will then have to backup the image to the hard drive and then later burn it to a cd? Can I use this bootable cd I will be creating to load Ghost everytime and then swap in the backup images to restore or will Ghost have to run from the cd (or does the backup image that I would restore need to be on a bootable cd)?
Edit: Don't know if those files listed are right cause I just did a search on my system and the only one that I even have is command.com.
Sounds like I need:
Command.com
IO.sys
MSDOS.sys
Mscdex.exe
ghost.exe
oakcdrom.sys
