Ghost 5.1c problem...Dump file is on Drive being dumped ???
leeland
3,659
i have ghost 5.1c and am using a 40 gig drive that is partitioned into two 20 gig drives c and d. when I run ghost and try to back it up with an image it only recognizes the drive as a 38 gig drive and not two seperate drives. I am pretty new with ghost and wanted to know does ghost need two seperate drives or can i use the partition drive to back up an image ???
thanks for the info
vash
2,510
<< i have ghost 5.1c and am using a 40 gig drive that is partitioned into two 20 gig drives c and d. when I run ghost and try to back it up with an image it only recognizes the drive as a 38 gig drive and not two seperate drives. I am pretty new with ghost and wanted to know does ghost need two seperate drives or can i use the partition drive to back up an image ???
Sounds like you are trying to backup your drive to a file on the same drive that you creating the image on. That is a no-no.
What you want to do is backup one of your partitions to a different partition. The menu option you are probably using is something like &quot;Drive to image&quot;. You want &quot;Partition to image&quot; because you probably only want C:. If you want to image your whole drive, you will need a second drive to place the file.
vash
Shagga
4,421
The term &quot;Hit the nail on the head&quot; comes to mind here.
vash - I believe is correctomundo!
leeland
3,659
thanks for the infomation, I got some directions from a friend, who has a two drive system, i didn't even think about that...just goes to show you that sometimes it is easier for someone that is outside of the problem to see the answer.
thanks for the information, i really appreiate it
lee
