- Sep 8, 2003
- 233
- 0
- 0
I wanted to purchase these fan noise dampeners Link
But checking around for a couple of days, couldn't seem to find anywhere with free or cheap shipping. So I took a trip down to the local Ace Hardware and found this: Link for $4.99 + tax.
Two 6" squares of 1/8" and 1/16" thickness.
I used the 1/8" piece for a 92mm fan and the 1/16" piece for a 80mm fan.
I used a standard fan grill to trace the outline with a metal scribe then cut it out with scissors. I used a couple of dots of super glue to stick it to the fan and let it set up. Meanwhile I cut out some small "washers" to put between the case and metal grill. I screwed the fan back into the case....
The end result was pleasing and most of the case resonance from the fans disappeared. Black rubber definately would of looked better, but I didn't see any.
