Gforce 560 TI Problem
malkuth
Had this card maybe 2 weeks already. Not sure if this is a sound issue or an actual driver issue. But what is happening that my screen will turn black for maybe a second or two and I will get a message that my Video Driver has crashed and recovered. Everything seems fine after that but I no longer have any sound coming out of the monitor.
Now I have the HDMI cable running right from my Graphics card too my HP W2338h widescreen lcd and the speakers are built into that.
I also Have my card hooked up to my Samsung 52 Inch LCD tv that I use to watch TV programs and stuff off my computer. But usually that is shut off and only running 1 monitor IE the HP when Im playing around on the PC.
I can get sound out of my regular Mother board built in sound if I hook up Ear Phones to my system. It seems to be an HDMI issue and for some reason the Sound Driver in Nvidia is crashing.
System is
EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB
G-skill Ripsaw series 8 Gig
GIGABYTE GA-Z68P-DS3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s ATX Intel Motherboard
I5 2500K (overclocked to 4.0 GHZ)
CoolMaster Hyper 512
Oh and if I reboot the PC everything will work again fine. And maybe in a few hours or even maybe a few days the driver will crash again. I can play eve for hours on end for a few days then it will crash radomly one day. Or I can be surfing the internet and it happens. No sound. Reboot all better until the next time it might or might not happen.
Try driver cleaner to remove all the old drivers, reinstall newest drivers and/or older drivers. You should also make sure you have the latest direct x 9 runtime installed.
What OS is this, Windows 7?
Check to make sure that video card has proper airflow / cooling in your case.
Also check the GPU temperatures when these crashes are occurring.
