ericlp
I got this card 3 months ago....
After the Fan was making this wird noise. I finally got messages that the Fan Speed was Slow. So anyway.. I just e-mailed Leadtek about the problem. Anyone here know how they handle the problem? Do they make you turn in your card? I'm thinking the Blue Orb will be a better solution since the next fan will most likly have the same problem.
If anyone has been through this or knows a good quick fix ... Should I let them put a new fan on it or should I just deal with it myself?
Also what is the best fan to get for a Gforce???
Seems like the Stock fan has Plastic Pins that clip into the holes to mount it.
Thanks!
Eric
Thanks!
Eric
