- Jan 4, 2001
- 41,596
- 20
- 81
Does the GF4 Ti4200 support the 32-bit Z-buffer? I've used Rivatuner to enable the 24-bit Z-buffer; I am under the assumption that 32-bit might improve image quality at a distance by cutting down on hidden surfaces becoming visible. That happens in a few games - as objects get farther away, obscured surfaces begin to shimmer into view.
Is there perhaps another good tweaking program out there that can help with this?
